I convert DV to AVI using VirtualDub and insert an extracted WAV audio file.
Video Codec: DivX Pro v5.0.3, 1000 Bitrate
Audio Codec: MP3 96 Kbits, 48 KHz.
Encoding Methods: 2-pass; 1st-pass, 2nd-pass through Job Control.
Filters: De-interface (Blend), Sharpen by 6.
The whole process seems to work fine.
When I go to play the finished file in Windows Media Player, the audio plays, but there is no video. When i try to re-open this file in VD and browse through it, VD crashes and the file information says it is still DV with a decompressor of MainConcept DV Demo v2.1.0. DivX Player says "Failed to open". BSPlayer says "Unknown file type (1).
Does anyone know what's wrong?
"Great Spirits Often Encounter Opposition From Mediocre Minds."
Just a guess, but it sounds like your compression settings for the final output were possibly to blame. Sometimes I will try a 'fast recompress', or 'normal recompress' to speed things up. Those options have given me simular symptoms like the original input codec, rather than the expected (selected) output codec.
What options did you have selected for the final output. Fast, normal, or full?Impossible to see the future is. The Dark Side clouds everything... -
Full processing.
"Great Spirits Often Encounter Opposition From Mediocre Minds." -
Open it in GSpot (find it in the TOOLS section), to view the codecs in the AVI. Something isn't right...
Here's what GSpot says:
Stream Type: Multipart Open DML AVI
Video Codec: N/A"Great Spirits Often Encounter Opposition From Mediocre Minds." -
I have no idea how you've gotten you the place where your at. I would start over at this point. Maybe take a more manual approach to the 2nd pass, and check your output afte a minute or so to make sure it's working as expected.
Choppy .avi playback to Xbox 360... only with .avi and only when streaming
By smitbret in forum Media Center PC / MediaCentersReplies: 12Last Post: 29th Mar 2011, 07:53 -
AVI playback problem
By venkman1984 in forum Software PlayingReplies: 2Last Post: 1st Jun 2010, 05:50 -
Philips 5982 & 624x352 AVI Playback Problem
By gonwk in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2010, 15:20 -
AVI Playback Problem.
By SteelersIHC in forum Newbie / General discussionsReplies: 4Last Post: 28th Jul 2008, 11:26 -
Avi playback problem
By alliedforces in forum Software PlayingReplies: 4Last Post: 27th May 2008, 14:06
