I bought one hundred ritek G03's form blankcdr.com and the first 50 spindle burned at 2X, by the way i have the sony DRU500A with 1.0f firmware. I opened the second 50 spindle and the first ten discs all burned at 1 X then one burned at 2 X then the next one at 1 the next one at 2. I'm pretty sure it's the media but in Dvd Decrypter it says there G03's so im begining to wonder if there's something else. Just wondering if any one else had this problem and if there was a solution?
Thanxx in advance.............
I have seen that problem myself. If you have Nero, do a CD-Speed check to see what Nero says the disk can be burned at. I discovered that sometimes the info that was read about the disk from a previous burn would some how still be used with the current disk. I just use Princo 2x brand disks now, and they always burn at 2x.
I have just recieved more G03's from shop4tech.com and the same problem some burn at 1X some burn at 2X. I upgraded my firmware to 2.0e and the first one 2X the next one 1X. So my question now is this, does Ritek make a TRUE 2X disc because I have had very good results with Ritek and have heard bad things about other brands like Princo's. Very frustrated almost an hour to burn a DVD is a long time.
Any help would be greatly appreciated,
Thanxx...........
Video becomes distorted at times.
By Nagashi in forum Software PlayingReplies: 3Last Post: 22nd Aug 2010, 21:24 -
SVCD2DVD Reg -3 times
By dr4son in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st Oct 2009, 18:45 -
By duzmor in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Sep 2009, 05:59 -
Transfer the times from one subtitle to another one
By mike007 in forum SubtitleReplies: 0Last Post: 22nd Mar 2009, 08:07 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 19:28
