Hello,
I have converted a NTSC mpeg file (352 * 240 29 fps ) to PAL (352 * 288 25 fps) using TMPG as explained in the HowTo Section of this site. I also use the noise filter in TMPG
I then burn the resuling PAL mpeg file to PAL VCD using Nero. The overall quality is infact better than the source NTSC file (perhaps because of using the filter) but with one problem.
The video image is not easy to watch. It is as if the image is going dark and then bright and then dark.... etc. rapidly. I do not know how is this phenomenon is called ( I'm sure there would be a name to this). This effect is not too much, still if I look at the original, the eyes do not get tired whereas the with the new CD, the eyes are getting tiered after a while.
Is there is a way to avoid this phenomenon. Any help would be greatly appreciated.
Regards,
Roh
Results 1 to 1 of 1
= bright and dark
By beetlespin in forum EditingReplies: 6Last Post: 16th Aug 2010, 18:38 -
Why Is My Screen Too Bright But Movies etc Play Too Dark
By Aaron1927 in forum ComputerReplies: 5Last Post: 30th Dec 2008, 10:42 -
Vegas 8 showing image too bright on finished video
By stantheman1976 in forum EditingReplies: 4Last Post: 18th Aug 2008, 15:33 -
Have an avi, but dark. Can I make it bright?
By ssalim in forum EditingReplies: 2Last Post: 15th Feb 2008, 11:51 -
How to fix a too bright & too dark issue?
By kinglerch in forum EditingReplies: 5Last Post: 5th Oct 2007, 23:37
