  1. Member scottb721's Avatar
    Oct 2002
    Australia
    In the Quantize Matrix tab on the Expert / Other Settings window there is a drop down box stating "Default". In this box is a CG/Animation option.
    Is this worth trying out for cartoons ?
    cheers
  2. Member DJRumpy's Avatar
    Dallas, Texas
    Yes. That's what it's designed for. The sharper edges and high contrast of animation, and CG will benefit from the custom matrix.
    Impossible to see the future is. The Dark Side clouds everything...
    Jan 2003
    Elkton, MD
    DJRumpy has it right...
    I've been using this for animation that I've captured from VHS and it works REALLY well...
    I use the bitrate calculator and TMPGEnc settings recommended over here: http://dvd-hq.info/Compression.html
    has yet to fail me
  4. Member DJRumpy's Avatar
    Dallas, Texas
    Most ignore them. They can affect your output in a very good way. I always suggest
    VCD: Ultra Low Bitrate (CCE only)
    SVCD/CVD: Very Low Bitrate (CCE only)
    DVD: "Standard" in CCE or "Default" in TMPGenc
    The "MPEG-Standard" can also be used for DVD. It would seem to lend itself to higher bitrates (high motion) video.
    The VCD and SVCD/CVD output in CCE looks excellent (for me at least), using those settings.
