I just updated tmpegenc to 2.59.47.155 and it is a definte step up for the old version but I cant get the audio from the avi to load up in audio source box ...when I load up the avi in the video source box it loads fine but does not load up in the audio source box like it normally does...when i click the audio source box to load the avi manually it says "can not open or unsupported"...I have never really had a problem with any of my converters and I have tried playing with the environmental settings but no dice......so when i go to convert it converts damn good but just with no audio...any tips?????
thanks to all that reply!!!!!!!!!!!!
Have you tried extracting the audio to a wav with virtualdub and then putting them back together in TMPGeng? This is what you should be doing anyway.. also give us the audio information that virtualdub reports.
Hmm maybe I should go through that in more detail. First open virtualDUB then go to
File > Open Video File.
Open the file that you want to extract the sound from
Click Audio > full processing mode
Then click Audio > conversion and select 44100hz and check the 'high quality' check box
Then click File > Save WAV and select the path you want the WAV to be saved at.
Load this wav in TMPGenc's Audio box. If VirtualDUB gives you the same kind of error that TMPGenc does when dealing with the audio you must not have the correct codec. If this is the case go to (in virtualDUB) File > File Information and tell us what is says for audio. Or try downloading and installing the NIMO codec pack (v5 build 8 ) and doing a full install of it. -
I have had that problem in the past. Saving the wav file, sometimes, not always, has caused me audio/video sync problems.
what I tried and worked was using VCDgear and converted the mpg to mpg.
It is also possible you don't have all the codecs.
VDub wont load *.VCF files in command line mode.
By zzyzx2 in forum Video ConversionReplies: 11Last Post: 15th Sep 2011, 06:48 -
virtual dub wont load the full vob
By tvlreject in forum EditingReplies: 19Last Post: 28th Mar 2008, 20:13 -
HDTV2DVD - .TS wont load
By NotSoEasy in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 15th Mar 2008, 19:09 -
dvr-ms at 59.94fps wont load
By dalego in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 7th Oct 2007, 17:38 -
xvid wont load in program
By dvdhouse111 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 6th Jul 2007, 04:26
