Where can I get 80mm case fans cheap? I need 6 of them and need them to have the 4 pin pass through connections. Quality cooling is what i am looking for.
Our local store sells them for 14 dollars each.
Results 1 to 14 of 14
Quality cooling costs a bit more. Recommend RPM-sensing fans with 3-pin connectors onto a thermal management system like a DigitalDoc5 so you know when your fans are going bad. Otherwise I'll be getting rid of 3 of my chassis fans to replace them with 3-wire units if you want to buy those. I think they're 60mm but I'll have to check again. They do have 4-pin pass-through connectors on them.
What is this DigitalDoc5? The reason for the four pin pass through's is because my motherboard only has 1 three pin connector. I was surprised when i got to looking in my new case and found places for 2 fans at the back and 4 at the front. It also has like 8 total 3.5 Bays. No front USB unfortunately.
DigitalDoc5 for a good price here:
http://shop.store.yahoo.com/directron/doc5.html
Read up on the unit. I just put one in my computer and like it a lot to keep an eye on things during long encoding sessions or to check the efficiency of my fans. Just because you have a ton of fans doesn't mean you're cooling your system well. You could get vortices inside the case from fans competing with each other. -
Wow that thing looks neat, may have to get one. Still need to know where i can order decent fans for a low price.
$14 for a 4 pin is a good price,after shipping & handling I would say your local shop has the best price.
Are you after brushless sleeve bearing fans or ball-bearing fans? The former are older technology, not as quiet, not as efficient, and don't last as long. I just went to the local CompUSA to get those new fans I was talking about earlier in this thread and they cost me $12 each for 80mm ball-bearing fans with 3-wire connectors. CompUSA fans are rebranded Coolermaster fans FWIW. Make sure those $14 fans at your local store are ball-bearing and that's not a terrible price.
I took 3 brushless 80mm fans with pass-through 4-pin connectors out of my case just this weekend. A friend of mine has them and may use them for a computer he's building for someone, but if he doesn't need them you can have them for shipping. I'd still suggest ball-bearing fans. -
So basically look for ball bearing fans. I wouldnt mind paying 14 bucks for 6 x 14 = 84. A lot of money for a broke college student
Do what we do to get extra money. Sell sperm and blood.Originally Posted by JamesB69
Check out www.sidewindercomputers.com for more fans. You can even listen to sound samples of each fan on their site which is pretty cool (no pun intended). I've already spent $200 in cooling supplies alone so $84 is just the beginning. The offer still stands for the brushless fans I've got if you don't mind the noise. They all work. They're about a year old. And they aren't really that loud, the old heat sink fans on my box were drowning out everything else I could hear in it anyway.
Also you very likely don't need to put in all 6 fans on your case. If you're running dual MPs then you'd want all the cooling power you can get. You should just be able to get away with a couple intake fans and an exhaust fan in addition to the power supply fan. Your CPU has a heatsink/fan on it doesn't it? I wouldn't worry too much about putting all 6 in then. I've got a Lian Li tower with 2 80mm intake fans, 1 80mm exhaust fan, 2 80mm fans on my 600W power supply, the tiny fan on the DigitalDoc5, a Thermlaright VGA cooler/fan, a chipset heatsink fan, and the two copper heatsinks for the CPUs with 80mm fans. I guess that's 9 fans total, but only 3 of which are intake/exhaust fans for the case (besides the power supply). I'm sure there's a way you can get away with less fans on your case. Maybe there's a spot for a couple 120mm fans? -
Have you tried places like BUY.COM?
Bought a few there once and I think they were pretty cheap like this one for $6:
http://www.buy.com/retail/product.asp?sku=10224245&loc=101
The StarTech.com 8cm x 8cm x 2.5cm (3 1/8" x 3 1/8" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 32 CFM (cubic feet per minute) of air. Power is supplied to the fan using a power tap that is connected to the large LP4 power connector on a PC's power supply.
If you want the 3 wire type go here:
http://www.buy.com/retail/product.asp?sku=10232527&hdwt=0&loc=101
For a whopping $6.75
The StarTech.com 8cm x 8cm x 2.5cm (3 1/8" x 3 1/8" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 32 CFM (cubic feet per minute) of air. Power is supplied to the fan using a 3-lead TX3 connector that plugs into the motherboard and allows the system to monitor fan speed and operating status.
And yeah I've used some of these and recommend them!
Need the quietest case fans money can buy
By neworldman in forum ComputerReplies: 4Last Post: 12th Jun 2011, 13:03 -
Fans are crazy!!
By alintatoc in forum ComputerReplies: 19Last Post: 4th Jul 2009, 05:13 -
External case - 3.5 or 5.25 case....
By kenmo in forum ComputerReplies: 3Last Post: 2nd Jan 2009, 15:54 -
Something for the hd dvd fans
By cracula in forum Latest Video NewsReplies: 4Last Post: 21st Mar 2008, 00:33 -
Do my fans indicate... stress??
By makntraks in forum ComputerReplies: 7Last Post: 14th Oct 2007, 19:14
