Help, I have a question? I am trying to capture and compress 2 hours of VHS video onto 1 DVD-r and want to know what is the fastest way of doing it. I have a Intel P4 2.4 533mhz bus 512MB, 120GB hard drive with a Sound blaster audigy. So far I am using sonic myDVD but it won't let me do 120 minute of 720 x 480 pixels plus when I capture it only does 352 x 240 pixels.![]()
I recommend using VirtualDub to capture the VHS at 352x480 with an MJPEG codec. (Assuming NTSC here). This will effectively capture ALL of the video data available on the VHS. You can capture at higher resolutions but you will not gain anything in quality by doing so. VHS maxes out at the 352x480 setting.
Note: 352x480 is basically 352x240 doubled... why? 2 interlaced fields each at 352x240... i.e. ALL of the video data available on the VHS source. Capturing at a higher resolution would be overkill and a waste of system resources.
Load the resultant AVI file in your DVD creating software and it should resize/display it correctly. (another assumption... sorry... not making DVDs yet) It will probably look like crap on your PC due to the interlacing but will play back correctly on your TV.
Of course this is just 1 opinion, but I'm certain of the 352x480 setting my own captures/SVCDs display perfectly using this. The filters in Virtual dub can conceivably "enhance" the quality of the VHS, but I've learned to NOT expect this.
Hope this helps!
NitemareEven a broken clock is right twice a day. -
thank you so much for replying, in that case Sonic myDVD can do that. So VHS can capture at 352x480 then how about DVD does it capture at this 352x480 as well? Can you make VHS into a high quality DVD disc? Is there any way? I need to fit as least 2 hour onto 1 DVD. Thank you for looking at this and replying.
You may want to check into the new 4.0 MyDVD suite, or DvdIt, as MyDVD on it's own, will inflate all your audio to PCM.
DVDit, will let you ac3 the streams. Hence not wasting half your disc space on uncompressed audio.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
is that DVDit le, SE or PE version? You know of any hardware that comes with DVDit LE? Thanks again.
Also you are referring to high quality from VHS to DVD right? -
Of course I should state again for the record that though I AM capturing VHS tapes I am NOT making DVDs out of them, only SVCDs. It's possible (but unlikely) that it can be done I suppose.
However, my SVCDs of DVD rips are excellent quality. My eye can't tell the difference between my discs and the original DVD. My video captured SVCDs look no better than the VHS, with the possible exception of using a color level filter to correct low light or overexposure conditions. Yes, it can be "improved" slightly, but it will not be DVD quality.Even a broken clock is right twice a day.
Capture Short Video Clips From 1.5 Hour DVD
By Grassman in forum Newbie / General discussionsReplies: 2Last Post: 27th Mar 2012, 00:52 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 09:38 -
I am trying (and failing) to compress capture card files....
By ladyhawke in forum Newbie / General discussionsReplies: 8Last Post: 30th Jun 2009, 21:55 -
Simplest and fastest way to compress LPCM audio to fit on DVD5
By kurbads in forum User guidesReplies: 5Last Post: 18th Sep 2008, 03:15 -
Capture, Burn, Distribue in same Hour
By hap123 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 00:18
