I have downloaded the Dolby Digital trailers & want to author my own DVD.
I renamed the files VTS_01_1 thru 8 because there are 8 files. Used IfoEdit to create an IFO file structure. When I look at the IFO structure, there are only 5 files (chapters?) listed but there should be 8. When I burn to a rewritable and play in PC DVD not all files play and not in the order specified.
I think it has something to do with how the internal coding is on the VOBs but I can't seem to find a way to change them.
Anyone have any ideas on how to create a successful DVD with these trailers?
MovieWatcher666
demux the AC3 audio and reeencode the video with the same bitrate as source file. then demus the video into elementary m2v stream and author the m2v and ac3 with IfoEdit.
Hey i made the same thing lot of fun :P
"Man who walk through airport turnstile backwards
going to Bangkok." -
Thanks for suggestions mysticgohan17.
Couple questions....what would you best recommend to re-encode the video with? Why does one have to go thru this if the files are in VOB format already?
In IFOEdit, you can only re-mux & author 1 file to generate the IFO files. How do you do multiple files (in this case, multiple trailers).
Amish Electrician...how did you do your DD trailer disk?
Thanks for the responses.MovieWatcher666
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 20:51 -
Dolby Digital 5.1-ch vs. Dolby Digital 2-ch
By coody in forum DVD RippingReplies: 6Last Post: 21st Jun 2008, 16:35 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 17:54 -
Making a short trailer
By B-Twien Bytes in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2007, 14:38
