Cheers allMy current operating system is WindowsME (yeah, I know) and my file system is FAT32. From what I understand, FAT32 has a 4 gig file size limit so in capturing video, you are limited to to that size. The "other" file system is NTFS, which does not have that files size limit so you can capture longer time periods. Is it possible to convert a WindowsME FAT 32 to NTFS file system? Or do I have to make the leap to WindowsXP and if so, is it even worth it on a P3, 1 gig, 528 ram.
Quess I am looking for an excuse to buy a new computer!
You create your own reality. Interested in media servers and HTPC? Can we talk?
yup, you have to go with either win2k or xp. win9x can't go ntfs. some say you can, but i'd rather go with nt. its a much better operating system. i got a P3 667mhz 190MB RAM and xp runs smooth on my machine.
Nope ME cannot do it. XP is better anyways, NTFS is just a plus. Your comp is plenty fast enough. Despite the minimum requirements I had a P1 233MMX, 64MB running it fine.
Try this.....it may only work with XP though.
open a command prompt (dos shell), and type CONVERT C: /FS:NTFS
OOPS ! Formatted my Mac HDD back to NTFS (had files) !
By NotSoEasy in forum ComputerReplies: 3Last Post: 6th Apr 2012, 00:31 -
Converting FAT memory stick to NTFS
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 15th Oct 2011, 00:47 -
FAT+ troubles with .mkv merged files
By fabpozzi in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Jan 2011, 10:29 -
Security bits in FAT & NTFS?
By G)-(OST in forum ComputerReplies: 9Last Post: 22nd Aug 2009, 14:16 -
FAT to NTFS
By hardy in forum ComputerReplies: 13Last Post: 24th Jun 2009, 15:24
