I'm going to put in a second hard drive and was wondering if XP will recognized it and ask to format it or what I will need to do.
If you stick with a major manufacture like Western Digital or Maxtor they came with formating software (recommended you use it) thats easy to follow and install.
Formatting software ?
Yeah ?
Just bang it on a spare IDE boot up XP, right click on My Computer, select manage, click Disk Management, find your new drive, make any partitions u want & format them. -
1)Click on: START+Help and Support
2)Search field, type: to detect new disks
3)follow the instructions...ed -
If you are installing a new Hard drive you may want to consider formatting it to NTFS specs as opposed to FAT 32. NTFS will allow you to have file sizes larger than 4 GBytes.
If you only have XP and have never upgraded from a previous version of Windows on your PC, then this probably does not apply to you, since the native XP drive format is NTFS. -
Thanks everyone !!! I'll be picking it up today and installing it.
Tip: Don't install a fast/new 7200 RPM dive on the same cable as a CDROM drive. CDROM/CDRW's may not be UDMA, thus it may force your drive to slow PIO mode. Faster CDRW's and some DVD drives will do UDMA 66.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Best format to store DVD's on a hard drive
By robrpb in forum Newbie / General discussionsReplies: 28Last Post: 7th Sep 2010, 22:46 -
Hard-Drive Recovery after Accidental Format with Other OS DVD
By jeanpave in forum ComputerReplies: 16Last Post: 21st Mar 2010, 13:59 -
hard drive files to burnable format
By peacock in forum DVD RippingReplies: 2Last Post: 25th Mar 2009, 18:50 -
Format Hard Drive
By danl_9x in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2008, 19:34 -
Hard Drive won't format
By waheed in forum ComputerReplies: 10Last Post: 16th Mar 2008, 16:14
