I'm buying a new computer and am thinking of getting a video card that can also capture video. The ATI AIW Radeon 7500 seems to have all the features I need. The video capture part is an adapter that is attached to a wire that plugs into the card. The adaptor has a number if jacks including s-video (which I'll use) and composite. Because these jacks end up attached to the same wire, does the adapture down scale the s-video to the level of composte? This would result in a signal that is less than the s-video signal.
Thanks....
Only if the composite & S-video connections comes from the same component. If you have the TV, for example, on S-video & the VCR on composite it will not degrade the S-video connection on the TV.
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 15:45 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 12:56 -
ATI AIW 7500 TV tuner washes out every 6 seconds, then back to normal
By Keitho in forum DVB / IPTVReplies: 0Last Post: 15th Jan 2009, 14:01 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
ATI 7500 All in One Wonder
By justmehere in forum Capturing and VCRReplies: 3Last Post: 8th Feb 2008, 16:08
