Hi,
Been having some problems with my Ricoh MP7080A writer, firmware is updated and using Nero 5.5.10.7. First problem is that it often dosen't recognise the media, only by opening the drawing and giving it a bit of a push does it then respond. I can burn VCD's no problem on to CDRW's at x4 but when I try and burn a CDR at x4 the picture breaks up and becomes all 'blocky' when played back on my DVD player. Any idea's to sort these problems would be gret.
Thanks, Zetor
Hello
I recenly had the same problem with my richo as it aged
i found it would do as yours mainly on cheap CDs
but worked fine with TDK white disks so you could give that
a try
But decided it might be time to replace my Richo
as i thought it might be age that was the problem.
Hope the media change helps.
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 08:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 07:23 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39 -
Ricoh Caplio R5 MJPEG and Video Studio codec query
By Pronto71 in forum Video ConversionReplies: 1Last Post: 19th May 2007, 22:30
