  1. Member wulf109's Avatar
    Jul 2002
    Is there anyway to change the I.D. 0x81 to 0x80 during DVD conversion?
  2. Yes.
    The easiest way is durring ripping. Just use vStrip(GUI). On the output TAB, use the RE-Mapping feature. You would select ID 81, remap to ID 80, and also deselect ID 81 from being ripped. Now you get a VOB that the audio is in ID 80.
    (PS-Hint) Hope your running NTFS, choose a vob size of 4096 or bigger, I have noticed doing this that the last byte before it splits to a new VOB, the audio has a POP in it, so to illiminate it, if the VOB output isnt cut up, then its perfect.
    Good Luck.
    VidHack
