DVDA 1.0a, build 184 is a bug-fixes only update. Fixes include:
A bug has been fixed that could cause an underrun on some machines when recording to -R and -RW media.
A bug has been fixed that always forced recompression of media with a 16:9 aspect ratio; 16:9 media files will be recompressed only when they are not in a supported format.
A bug has been fixed that could cause an error while erasing DVD+RW discs that were previously burned with some third-party applications.
A bug has been fixed that prevented some discs from playing on some software-based DVD players.
A bug has been fixed that prevented on-screen and front-panel timecode and chapter information from displaying on some DVD players.
In some scenarios, the estimates of media size/space was off. Now fixed.
Prepare Wizard now properly updates when asset settings changed in Optimize DVD dialog.
Perfomance slowdown when there are >10 nested submenus, fixed.
Support for Postscript fonts, and several international text fixes.
Fix made so that text doesn't look "chunky" on some DVD players.
http://www.sonicfoundry.com/download/step2.asp?DID=437
