I've seen advice here and in other forums that when you've got a properly-authored DVD, and drag the VIDEO_TS and AUDIO_TS folders to Toast, you should delete the .DS_Store and any other files that appear. Every time I try this, the burn fails eventually. Projects burn just fine if I leave the disc structure alone. I haven't had a problem with my set-top boxes reading DVD's *with* .DS_Store, Desktop DB and Desktop DF invisible files, but am I headed for trouble i f I keep leaving them in?
Thanks!
Curt
Under toast, you need to select DVD under the OTHER tab.
I am not sure if this will create a .DS_Store file or not.
Another option is to double click on the Disc in toast, and check the box USE EMPTY DESKTOP DATABASE.
My player does just fine with the files there, and your should too...
Hope this helps. -
Originally Posted by ZeroSix
Problem burning subtitles and movie to DVD with Toast
By Akominatus in forum MacReplies: 40Last Post: 14th Apr 2013, 14:28 -
Burning a DVD ripped with MTR without the Toast application
By FilmLabAsst in forum Newbie / General discussionsReplies: 1Last Post: 20th Sep 2010, 11:58 -
burning a DVD in Toast
By lalilyman in forum Authoring (DVD)Replies: 3Last Post: 30th Mar 2010, 22:11 -
burning clips with toast
By 3mselect in forum MacReplies: 6Last Post: 29th Oct 2008, 12:54 -
After burning in Toast: subs: no and yes.
By Levina in forum MacReplies: 7Last Post: 13th Apr 2008, 16:50
