  1. Hi all,
    exists an utility program to know if a MPEG2 stream is interlaced or not?
    Thanks in advance
  2. Member DJRumpy's Avatar
    Dallas, Texas
    Just open it in DVD2AVI, and press F5 to preview. It will tell you if your source is Interlaced, Progressive, or FILM. Film indicates pulldown was used. You can remove the excess frames to return a FILM MPEG to progressive using the VIDEO | FIELD OPERATION | FORCE FILM option, and saving it as a new AVI, or frame serving it to your encoder of choice. Read the GUIDES section for help on DVD2AVI, and general conversion.
    Impossible to see the future is. The Dark Side clouds everything...
