Hi
Its telling you that the mpeg to made is not correct for a compliant VCD.
When you made the VCD mpeg you did not make it correctly to be compliant.
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
"Anything" diffrent from one of those settings will make a none compliant VCD.
If your using TMPGEnc then load a template, and do not change anything.
Ignore the warnings, can render them usless on some players, if not on yours but on other people's.
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 14:26 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 14:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 12:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 15:27
