Poll: What DVD ripping program do you use?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 12 of 12
    Dec 2002
    Scotland
    Hello I have been using DVDDecrypter for ages now and I was just wonder what DVD ripping program other people use and why you use it.
    Best Regards.
    Barry
    God's in his heaven... All's right with the world!
    Robert Browning (1812 - 1889)
  2. I use my Penis. I smack it against the disc a few times while hollering like Tarzan, and walla
  3. usa DVD Decrypter also
  4. Also DVD Decrypter for me...
  5. I use DVddecrypter for dvd to dvd-r's. For my cvd stuff, I use the program that is used in dvd2svcd. I was using claddvdXP or whatever it is, but got tired of the stupid thing expiring all the time.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    At the moment none of the above: I use vobcopy, as I've taken a forage into LinuxLand! Good Lord, are Windows users spoiled with all kinds of pointandclick packages!
    /Mats
  7. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    At the present time I use cladXP to rip. I have used that to rip since I started ripping.
    I burn with decrypter though and I have started ripping a little bit with decrypter from time to time.
  8. I use DVD Decrypter. I read that it's the best.
    It's not that I don't understand, it's just that I don't care!!!
    Feb 2003
    St. Louis, MO
    DVD Decryptor
  10. i use smartripper
    Jul 2001
    Sacramento,Ca
    I use dvdxcopy and there have been only 2 movies that messed up, The Green mile, it plays straight thru with no problems as long as u dont use the menu and LED ZEPP THE SONG REMAINS THE SAME it just errored at the end of the movie but plays fine. I see though that movies with episodes sometimes wont copy because it wont split an episode thus making some too large to copy on the second disk. I used dvd decrypter and it works great but when i use nero (latest demo) to burn I find my copies are less likely to play on some players. So whats the best burning program out there thats gonna work on the most players (stand alone)
  12. Member Nitemare's Avatar
    Jan 2003
    BarryHL,
    Great question! I mainly use CladDVDXP. I started using this because I believe it was the first program (I found) that would let me select PGCs and rip an entire movie to a single VOB. Since then, newer releases of other ripping programs allow the same options but I still mainly use this program because it works faster than the others on my system.
    I also use DVD Decrypter and Smartripper because once in a while CladXP may choke on a rip that either Smartripper or DVD Decrypter will sail through.
    ALWAYS keep your options open!
    Even a broken clock is right twice a day.
