I've been investigating about this around the web, but I haven't gotten a straight answer. I've found that DVD can, in fact, use MPEG-1, as long as it conforms to the VCD standard, which requires the video to be at a resolution of 352x240 pixels with a CBR of 1150Kbps and a framerate of 29.97 FPS (NTSC). Audio must be at a bitrate of 224Kbps and a sampling rate of 44.1KHz (MPEG-1 Layer II). These specifications are used where playing time is more important than overall quality. What I want is an accurate answer from someone experienced, not an amateur. Would using these settings to create a backup of a DVD, result in a compliant DVD-R that will play on a set-top box DVD player? Thanks in advance.
I've read the guide available on this website, regarding this subject, but I find it lacking of otherwise important information and it's addressed very vaguely...
I've kept investigating and I found that video can have a bitrate higher than 1150Kbps, up 9.8Mbps (according to the sources from where I gathered the information) and audio can have a maximum CBR of 384Kbps and a sampling rate of 48KHz.
Yes, you can use mpeg1 with similiar settings to VCD on a DVD. The audio must be 48 khz and you can not use vcd ntsc film(23,976fps).
www.dvdrhelp.com/dvd#tech
www.dvddemystified.com -
MPEG-1 video rate is limited to 1.856 Mbps.
http://www.dvddemystified.com/dvdfaq.html#3.4 -
baldrick is correct.....ive done this a few times, like with an advance of the new lord of the rings
True Story
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 12:31 -
Dif / DV25 & Wav to MPEG (suitable for DVD burning)
By sevenleaf in forum Video ConversionReplies: 0Last Post: 21st Aug 2008, 05:33 -
Golf Swing & Mpeg & AVI video Streaming
By jamesh2 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jul 2008, 08:19
