I just want to convert some AVI files to MPEG2 to make a SVCD with. Should be simple right? Check the AVI's are good, run 'em thru TMPGenc plus using the standard template and there you go - job done. Not happening - they are encoding alright but seem to be playing back faster than they should - easily noticed in the audio. What the heck is going on here? I can encode them as MPEG1 no problem. I can even encode using the PAL DVD template and the file is fine. I have tried AV files from my JVC DV cam and from analog captures. I have tried QT files from other sources. Same story. The gear I am using is a follows:
Athlon XP2000
Soyo KT333
2 x BarraCuda IV 40 gb
1gb Samsung PC2700
Matrox G550
Decoder is Matrox Cineplayer. I suspected that this may be the culprit but it seems to play back real DVDs fine
I should mention that I just tried it on my other PC, a lowly Athlon 650 - same results. I am UK based so all settings both in and out are PAL/25fps.
Any help appreciated - this is driving me nuts.
Results 1 to 1 of 1
Decoder Vp7 to Mpeg2/DVD
By bebado22 in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2010, 13:22 -
video files play back too fast
By kbly in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 11:41 -
Problem with mpeg2 decoder.
By tehuser in forum Software PlayingReplies: 5Last Post: 24th Mar 2009, 18:59 -
Palying Raw .DV files on Digital Media Receiver
By pakawufs in forum Media Center PC / MediaCentersReplies: 0Last Post: 16th Nov 2008, 13:00 -
Mpeg2 decoder library for developers
By Ufit in forum ProgrammingReplies: 3Last Post: 27th Dec 2007, 02:56
