I having a problem with subtitles in IC for the movie The Ring.
The language text to identify which boxes to check is missing in the IC program. The boxes are there and functional however. I strip down to movie only before I feed into IC. The method I use is rip the main movie files only (VOB 1-7 only) and then use IFOedit .95 to create IFO's by the create IFO funtction. Then feed the movie only into IC.
I follow this guide https://www.videohelp.com/forum/userguides/147636.php
to strip down to the movie only beforehand.
I also tried using the get vts sectors after the new IFO's were created but that didn't help either.
Anyone have any suggestions. Help would greatly be appreciated. I am a Newbie. :P
Results 1 to 1 of 1
forced subtitle problem in avi.net with dvd rip of main movie only
By nathanm in forum SubtitleReplies: 0Last Post: 30th Apr 2010, 09:37 -
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 16:54 -
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 10:43 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
Menu swapping with IfoEdit - Problem solved
By Bingo-days in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 03:07
