Can you burn a dvd-rw disc in data mode? What program can do it? I tried Nero Express which came with my burner but it would only burn cd's.
Yes, in fact -RW and +RW are used mainly for backing up data. Us video encoding nuts here actually are the minority. But most non Video nuts use re-writable for data cause they can backup, and append their backup, or erase it and do a more currant b/up.
I use it for both. Mainly data, but also for testing a DVD video if I'm trying a new authoring technic just to avoid a DVD-R coaster. Well my rewritable is DVD-RAM, but same concept here in this discussion.
SeanWe all like Sheep have gone astray... -
Maybe this will clear up some things:
While CD's can come with different types of specialty tracks...- Audio (2352byte)
Mode1 and XA Mode2Form1 General Data (2048byte)
Mode2 AV-Data (2336byte)
XA Mode2Form2 AV-Data (2324byte), e.g. PhotoCD Imagepak, VCD MPEG
DVD's only come as ONE track type -- Data. Even more specifically, a Mode1 Data track, using the UDF or UDFbridge filesystem.
That's ALL DVD's. Everyone of them. The difference is in the APPLICATION / Presentation type. That's where DVD-Video is seen only as IFO/BUP/VOB files in the VIDEO_TS folder, DVD-Audio is seen only in the AUDIO_TS folder, and other types of data are seen in other folders.
This actually simplifies the choices in the burning process. On the other hand, AUTHORING can now be more complicated.
This also helps explain why one can't just directly transfer material to DVD's from AudioCD's or VCD's. These specialty track types don't exist in the DVD realm.
Now, I still haven't gotten a handle on how multisession and MRW figures into this...
My $.02 worth,
Scott - Audio (2352byte)
So can anyone reccomend a good program for general archive use with my dvd-rw?
Nero, or Nero's DLA Program called IN CD. Either will work. Nero will burn a data DVD just like your used to burning cd's. IN CD Will let you drag and drop to you -RW just like a floppy, but remember when using rewritable media you gotta format it first.
Can Vista burn data DVD?
By vid83 in forum ComputerReplies: 6Last Post: 22nd Feb 2009, 18:15 -
How to burn DVD data with Nero 7?
By Kakui in forum Newbie / General discussionsReplies: 5Last Post: 28th Oct 2007, 17:00 -
Cannot change burn speed with DVD data projects
By mekuka_pinasem in forum DVD & Blu-ray WritersReplies: 14Last Post: 20th Aug 2007, 21:43 -
How Do I Burn A DVD Data Disc ?
By vidgo11 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2007, 13:15 -
How to avoid data burn to bad sector of CD/DVD RW ?
By kclgad in forum MediaReplies: 1Last Post: 31st May 2007, 08:17
