  1. I won a copy of ACID Pro 4.0 in a contest. It said that you would be able to create 5.1 DD mixes. However, it turns out that you need a $399 plug-in from Sonic Foundry to encode AC3. Either that, or a "compatible third-party encoder."
    After playing with the software for a while, I think that the only output option that ACID gives is 6 Mono WAV files.
    Is there any way to create 5.1 DD from these 6 Mono WAV files? I remember BeSweet having an option to make AC3 files, but I think it only works for stereo, at most.
    Is there any way to store 5.1 DD information into one WAV (or similar type) audio file? Or is there a way to turn the 6 Mono WAVs into a Dolby Surround (Pro-Logic) stereo file, so that I could maybe at least get Dolby 2.0 Surround?
    I was very lucky to win the ACID software. I have some film projects I'd love to mix in 5.1 for DVD, but I have no money at the moment.
    Well, thanks for any help you all can provide.
    -J
  2. be sweet has an option to make a 5.1 AC3 file. on the right click AC3 & Ogg Then tick the box that says "Create 5.1"
    However I have no clue if you can load multiple wav files into it.
    Sean
    We all like Sheep have gone astray...
