Well after having nasty Hardrive problems, and giving up on KVCD due tothe slow PC, it's back to good ol SVCD;s...I converted Eddie Murphy Delirious, to VCD, but realized that it was already an Mpeg VCD Standard some idiot had it renamed to .AVI, well anyway I actually converted the file into an XVCD, and the sound got all weird, I changed the 41,000HZ to 48,000HZ, and 224 to 192KB/s, and Joint Stereo, the voice had become very deep as in develish, but not soo much but you get the idea...could someone explain what went wrong, or is it the burning program, I am using Nero...
Also it seems to be already converted to VCD, would it somewhat make the quality better IF I made it into an XSVCD....?
COuld someone explain these HZ settings aswell, clarify a little bit more because it would be beneficial...![]()
Check out my guide on converting .OGM format to an SVCD with Selectable Subtitles and Multiple Audio tracks.
https://www.videohelp.com/forum/userguides/170944.php -
VCD&SVCD are 44,100Hz(DVD is 48,000Hz) and don't use joint stereo full stereo is better.To the question of converting VCD to SVCD:you won't gain any quality.
So, IF I change it from 41,000 HZ to 48,000HZ it can cause problems right...?
System build help - $1,000
By magillagorilla in forum Media Center PC / MediaCentersReplies: 19Last Post: 20th May 2011, 12:55 -
How to change framerate in XviD4PSP other than 15.000 ???
By d003232 in forum Video ConversionReplies: 0Last Post: 26th Apr 2009, 14:24 -
Editing FLV with AVIDEMUX gives 0.000 video
By toryamos in forum EditingReplies: 0Last Post: 12th Sep 2008, 00:41 -
problems with 10,000 BC DVD disc
By Gabriella555 in forum DVD RippingReplies: 2Last Post: 3rd Jul 2008, 08:35 -
Video from Sanyo VPC-HD !000
By peterfb in forum Newbie / General discussionsReplies: 1Last Post: 13th Apr 2008, 07:39
