i'm using divx 5.02 and i'm trying to find some good settings to get 2 hours in 700 MB so i can fit it on one CD. i know its possible to get good quality like that, i have many DVD rips that are 700 megs and have excellent quality. i'm aware that these are 2 or more pass encoded, but i'm trying to encode some videos with at least comparable quality. i have a leadtek TV2000XP and use their winfast PVR software to capture. i just want to be able to capture in one pass and get some decent quality.
i'm using a 550 bitrate, with my advanced settings at default, except for the RC averaging period at 27000 frames (15 min) and the RC reaction to 25, instead of 20. however, the quality isnt that great at all, and it gets pretty blocky when theres high motion. i have the psychovisual elements to normal, and the keyframes set to 120 frames. these settings give me a good 175MB/30min which is pretty much exactly what i want, but like i said, the quality isnt too great. any suggestions on how to get better quality? ive seen these tables which tell me to use around a 700 bitrate, but that goes WAY over target.
oh yes, i'm using the mp3 codec, which at these settings are about 7k/sec. thanks
Results 1 to 1 of 1
Are my capture settings ok ?
By smartel in forum Capturing and VCRReplies: 107Last Post: 29th Mar 2012, 10:13 -
Video Capture Settings.
By Green_Tape in forum Capturing and VCRReplies: 1Last Post: 4th Oct 2011, 22:37 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Capture Settings for Divix
By Nosey249 in forum Capturing and VCRReplies: 2Last Post: 13th Feb 2010, 17:45 -
Assistance with Capture settings
By kiwiusa in forum RestorationReplies: 0Last Post: 14th Jan 2008, 18:41
