Hi, my first post![]()
What is the best way to convert dvd-svcd ?
I use dvdx and compress to 1800 bitrate and good motion search setting.
I think the quality sucks when I watch the movies on my TV, is there any better prog to use that will give me better quality but same size (mb)?
100 min must fit on 2 cd, with 1800 bitrate I get about 1600mb with 100mins, which fits on 2 cd.
Or doesn't it get better with that bitrate ?
Thanks for your help.
what do you mean by the quality sucks?
I dont know whether you are being really critical over a good SVCD, or made a crappy one, that could be improved.
How does it compare to standard VHS? -
Use DVD2SVCD. Run it overnight (unless you have CCE). Quality is as good as you want it ( you can control most of the factors, including number of CDR's and some bitrates ). I have some SVCD's that you are hard pressed to tell from the original DVD ( on a 27" TV ).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
ok, thanks.
Just have dvd2svcd running a dvd now. Hope that will work better.
Do you fit 90 mins on 2 cd with that dvd like quality ?
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 03:32
