    Dec 2002
    Nuneaton
    I have LOTR Box set and I am wanting to put the film onto 1 DVDR. I am guessing I can rip both discs so I just have the movie. Disc 1 and Disc 2, so when I have ripped both DVD's how do I then put them together to make it fit onto a DVDR?
    Just the movie no extra's
    Why are the best things things in life cost the most money?
    Who stole the rest of my Signature, Own up, it was you, yeah you, thats it I am gonna come over there and ..........
  2. I haven't tried this yet, but it seems I read that you rename the vobs (from both discs) with the same name and in a sequential order. Then use IFO Edit to "join" them. From there it is a matter of re-encoding. Hopefully you will be able to preserve the ac3 sound. That is the only question I have at this point.
    Darryl
    Dec 2002
    The Great Northwest
    How to reduce and fit LOTR on............
    http://www.dvd9to5.com/LOTR2.htm
    LOL
    Dd
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
  4. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    You can do it with IFOedit. Just like the other post said as long as the full movie will fit onto one DVD-R disc. Just rename the VOB files in sequential order and you should be good. Don't forget to get the VTS sectors and region free it!!
  5. Don't give in to DVD2ONE, that leads to the dark side.
