ok, my movie is ok, but when i get to the burning part, it gives me a problem about the disc size. the dvd blank is 4.7gb!! and it only needs 3.9gb!! I chose "retry" and then my computer just freezes up. can anybody PLEASE help! PLease!!!
Actually, a formatted DVD holds around 4.4Gb, but if you only need 3.9, then that's not the problem.
Are you sure you selected DVD as your format for the project and not VCD? Could it be that it is assuming you want to create a VCD on a 700mb CD?
I use DVD MF2 but have never run into a problem like that. If you can provide more details or a screen shot maybe we can assist further. -
Also, if your movie file is that large, make sure that you have the audio set to mpg and not lpcm, otherwise with the audio uncompresses you'll have some problems.
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 08:48 -
I have a problem using Ulead DVD Movie factory including.AVI Files, the pro
By OggO1984 in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2009, 08:42 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 12:22 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 10:59 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 03:26
