I have an avi which according to Vdub is 15 fps - wtf is this??? I guess CCE etc will not let me encode this???
How do I get it to SVCD?
some DivXs are weird framerates, most commonly TMD, SMR and other screwed up, poor quality avis that are so popular on KaZaA. Dunno about CCE...but TMPGEnc can convert framerates, so I would guess that there is something similar in CCE. Encode it how you would normally encode SVCDs and see if it works. I would suggest using TMPGEnc myself though, if CCE won't do it. But the resulting file might not play smooth, as frames have to be duplicated and deleted, but then you might not notice it.
My advice is dont even bother with converting those 15fps movies. They are crap quality and will end up looking like your watching your TV stading behind a dirty screendoor. Dont download those 300mb full length movies. get the movies that are 2 700mb files.
Here's a guide using TMPGEnc for low bitrate/odd fps conversion.
"Art is making something out of nothing and selling it." - Frank Zappa -
Oops! Sorry. http://www.vcdhelp.com/forum/userguides/91597.php
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
