What format should the text be in, in order to create chpater points? Im guessing i have to find the time in which the scene changes and put that in the text, but im not sure what format....
any examples would be great.
if you are authoring dvds with ifoedit. don't even bother trying to add chapters because it has some sort of bug in it. i tried to do it and i found out from other people that it has a bug.
I have never had a problem adding the cell times for authoring with ifo edit
Just open the main move ifo with ifo edit, then go to the top white box and double click the line that says VTS_PGCITI
Then just under that a you should have your main movie PGC which should look like this VTS_PCG_1
Right click it and go to save cell times
There you have all your chapters in a text file ( thats already IfoEdit compatable) ready to add to your M2V,AC3, and Subs
thats strange thats what i did when i used ifo edit and the video would freeze when i played it on my dvd player. that seems like ages ago. man how things change.
that is for NTSC films only.
http://dvd.coldpie.com - where you can download versions of DVD2DVDR. -
well, heres the thing, i have a downloaded movie (no original IFO) and i have converted it so that i can burn it to a DVD, i do this all the time, but i never have chapters and its like having a old VHS tape in my dvd player(fastforward and rewind) I went into VirtualDub and went through the movie frames and typed the frame numbers in a CellTimes.txt when i saw a good chapter point (scene change), but after burning i saw that the chapters werent even close to what i had originally, they were cut all over the place. The only thing i can think of was that i used the original AVI to check frames for chapter cuts and not the MPG used for the final burn. any thoughts? and program to check frame with MPG?
Been looking at this strange feature. I think its preset for 30 FPS not the 29.97. If I did 29.97 as a start it made a mess out of it. If I use 30 for the caculation it comes out pritty close and its a small precentage off.
So 5 minutes is really
(((H * 3600) + (M * 60) + (S) )* 30) = Frame
(((0 *3600 ) + (5 * 60 ) + (0))* 30) = Frame 9000
Here is a run on a m2v file With 5 minute spacing between chapter points
CALC Actual Time Frame
09000 05:00.16 9016
18000 10:00.07 18007
27000 15:00.04 27004
36000 20:00.11 36011
45000 25:00.17 45017
Working on a small program where I can scroll through a video and build a text file from the selected points. If works, may post.
I am wondering on what the format to feed IFOEdit to do a Menu right now.
DVDslideshowGUI stopped creating VIDEO_TS. IFO & BUP files
By gobettee in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2012, 15:52 -
disable creating of Log.txt files (eac3to,mkvmerge,mkvextract...)
By mkvonly in forum Newbie / General discussionsReplies: 3Last Post: 9th Nov 2011, 12:36 -
Can IFO-Edit merge files?
By Djard in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2011, 11:50 -
creating .ifo from .vob files and keeping menus
By vishalpatel1 in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2007, 08:40 -
using ifo edit
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 07:19
