When I convert DV video into DivX without the audio and play it in Windows Media Player 9.0, it plays fine. But, when I convert with the audio, I get either: audio only and visualization, "WMP has encountered an unknown error". When I try to play it with DivX Player, it says "Failed to open". When I try to play it with BSPlayer, it says "Unknown file format".![]()
VirtualDub (Newest version)
Video codec: DivX Pro v5.0.3, 1000 bitrate.
Audio codec: MP3, 96 Kbits, 48 KHz.
Filters: De-interlace (Blend), Sharpen by 6.
Encoding method: 2-pass through job control.
Does anyone know how to help me figure this out?![]()
"Great Spirits Often Encounter Opposition From Mediocre Minds."
Try 128 Kbps 44.1 Khz audio. Do you have the DV audio codec installed? versus some Directshow filter that would let you play it( it's not the same thing ). Can you convert just the audio so it would play in an MP3 player? You can do the audio seperately and merge them with VDUB.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I believe all I have for DV is MainConcept DV Demo v2.10. Yes, I can convert the audio so it will play in an mp3 player (Winamp). Yes, I know I can merge them with VirtualDub. That's how I do it.
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 10:31 -
Produce a REAL playable clip for Mobile?
By cigarshaped in forum Newbie / General discussionsReplies: 2Last Post: 5th Oct 2008, 18:16 -
Cutting a short clip from a DVD
By Nutmeg7 in forum MacReplies: 1Last Post: 13th Nov 2007, 23:58 -
Short video clip to stills
By swkenney in forum Video ConversionReplies: 2Last Post: 16th Sep 2007, 13:25 -
How to make a short clip?
By kenzo69 in forum ffmpegX general discussionReplies: 2Last Post: 18th May 2007, 20:15
