When I prepare the avi in virtualdub and do a bad frame test and then switch to frameserver.
Then when I use CCE or TMPGenc it never completes i always get an error. Sometimes it happens at the same time/frame and sometimes at different times/frames.
I've tried it on several different avi's but al the same problem.
Can someone explain or help
thnx
You are not giving us enough info to be able to help!Originally Posted by marcodark
I suggest you pick one of your problem avi's. Follow your procedure and not where it fails. The post details of the avi (file->file info in vdub is good for this) and also the nature of the failure. Yous say it doesn't complete, but in what way. Do you get an error message, if so, what is it, if not does your PC crash or does it simply stop encoding. Help us to help you and you might get your problems solved. -
More info:
there are several problems:
One i don't get
If i do a 3 pass then the 3 passes go by in a couple of seconds and then it's ready, but no output
(avstodvd) Converting m2ts to dvd...sudden sync probs.
By newbtube in forum Video ConversionReplies: 17Last Post: 3rd Apr 2011, 00:27 -
svcd/mp3 probs w/new players
By blujayhill in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Jun 2009, 11:28 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 21:13
