I recently bought a DVD-R trial pack from Bigpockets.co.uk. All of the DVD-Rs worked perfectly in my Sony DRU-500AX except for the White Label, which was the only 2x disc (the others were all 1x).
Every time I tried to burn with the White Label, I got a dialog box popping up in DVDit PE 2.5 saying "The recorder cannot use this disc" - and this was as soon as the burner accessed the disc during the build, it wasn't like it crapped out in the middle of a burn.
What conclusions can I draw from this? Is it that my burner just doesn't like White Label 2x discs, and a different brand of 2x media will work normally? AFAIK the DRU-500AX is 4x-compatible out of the box and doesn't need the firmware update, so I'm assuming that it's probably not a firmware issue.
I bought a DRU500A while version g of the firmware was already out. I discovered the drive had a 1.0d version of the firmware.
With this version, the drive would not recognize several brands of disks, more of the 2x type. It also had problems with Verbatim DVD+R 2.4 media.
Check the firmware version. If it is not at least f or g, consider upgrading. It's safe although it requires several reboots.
One word of warning though. With the d version of the firmware, I was able to record at x1 on certain DVD-Rs. Upgrading to 1.0g solved several problems, including identifying unusable media at x2 and burning them OK, however the disks I was originally able to record at X1 were now identified as X2 but recording failed halfway through (simulation succeded). This has to do with Nero and the various bug-ridden versions they issue lately. Just to warn you that recorders, software and media are very immature yet and compatibility and succesful burning should still be a higher priority than speed.The more I learn, the more I come to realize how little it is I know. -
Glorfindel - I have the DRU500a and DVDit, however I can't seem to burn within the DVDit software. I use NERO for all my burning. Try another program to see whether it's the software or your media. I like DVDit, but it is finicky.
I have only used name brand media - Sony, TDK (white & silver), and Maxell. I have only burned one coaster (a sony +RW) when my system crashed unexpectedly during an attempt to erase. -
My burner is the 500AX, not the 500A or UL. On their support website, Sony specifically state that the 1.0g firmware upgrade should *not* be applied to the 500AX. Unless I missed something, the AX already contains the correct firmware (and my burner was manufactured in Feb 2003, which backs this up).Check the firmware version. If it is not at least f or g, consider upgrading. It's safe although it requires several reboots
I've found that if I use the "test and burn" option, the test works OK, but then DVDit stops with an error when it tries to start the burn.Glorfindel - I have the DRU500a and DVDit, however I can't seem to burn within the DVDit software
If I use the "burn only" option, everything seems fine. -
As mentioned previously, White Label 2x.
I've just checked the Bigpockets site, and it seems that they recommend White Label discs for Pioneer burners only - so that could well be the problem. Good job I only got the disc in a trial pack!
I've ordered a different trial pack from dvd-rmedia.co.uk, and it comes with a variety of differently-branded 2x discs (the Bigpockets one only contains a single 2x disc), so let's see what happens! -
I have the DRU-500UL, which is basically the same burner after the g firmware update. I use Verbatim, either +R or -R media, whichever my local BestBuy has in stock. A 15-pack spindle is $40 ($2.66 ea.) or the 50 back is $100 ($2 ea.). I am also starting to use Samsung/BeAll -R media purchased from AllMediaOutlet.com, I get the jewel cased ones with the ivory top (for asthetic reasons I dont like silver top disks). These Samsung disks are not labeled as 2x but burn flawlessly at that speed, $80 for 50.
AllMediaOutlet has a sampler pack for the Sony dual format drives, check it out. It's a little over 20 bucks and you get 12 disks, 2 of which are 4x. BestBuy also has 4x Verbatim disks for $3 apiece. Bestbuy's prices for +R and -R are the same, although they don't always have both in stock. What I ususally do is order on line and pick up at the store. But so far, all set top players I've come across dont have any problem playing both +R or -R, I'll likely just buy whatever they have in stock.
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 12:00 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 22:55
