  1. ok guys i have an xvid that i have demult into a m2v file and an audio file to match but when i try and import into dvdmaestro it comes up with incorrect frame rate .
    the frame rate is 23.97 what can i use to convert the frame rate of the xvid i have tried aviframerate changer v1.10 but that doesn't work with xvid's is there a tool out there that does
    help greatly recieved guys
  2. it seems that you have to add a pulldown 3:2 when encode to *.m2v
    so the file when plaied serve the TV as 29.97fps (some like that)
    wait for another help or try some guides
    and if using TMPG to encode try Kwag´s template
    2man
    Mar 2002
    chicago
    go here:
    http://guiguy.wminds.com/downloads/pulldownbatchfe/
    run that on your .mpv file before you import into dvdmaestro
    what are you askin' me for...
    I'm an idiot!
