I am not currently at my computer now that I do my backups on so I cannot tell you what file extension they are in exactly but I would like to know if anyone has been using Nero or RecordNow Max and how they have been using that software to burn those files to get a playable DVD for a set top player.![]()
Results 1 to 9 of 9
well for nero just follow the wizard for dvd video. as for recond now just burn in data mode. just make sure you create a video and audio files and that they are in caps.
Instantcopy burns the disc itself, no need to use another program.
RealaT Bytes, but that's what life is. -
Use PDITOOL to extract all the files from the PDI images on your hard drive. You can download it from here:
http://forum.doom9.org/showthread.php?s=&threadid=47259
Then just burn the files in the normal way.
With InstantCopy you're much better off saving the project to your hard drive first rather than letting it burn straight to disc because it is so awful at predicting the final size. For instance, if the project only ends up at 4GB on your hard drive you can always redo it and up the output size a bit to get it closer to 4.37GB. Time consuming maybe, but at least you're getting the maximum quality possibly on your discs. -
InstantCopy *CAN* burn the disc itself, but he's obviously already saved the files to his hard drive.
Use PDITOOL to extract all the files from the PDI images on your hard drive. You can download it from here: -
InstantCopy will burn the PDI files from your HD to your DVD disk directly, there is no need to extract the files unless you want to add or change something.
This method does give you the AUDIO_TS folder. The latest update adds the AUDIO_TS folder for compatibility. On the previous versions, the AUDIO_TS folder was there also, if it was on the original DVD.
At the end of the day everyone should use the software as they see fit, but for me there is a very good reason not to burn either straight to disc or straight from the PDI files with IC7. For an extra 10 minutes wait it seems daft to take the chance. -
IvIark,
I want to thank you for the link to the PDITools after installing them and changing the *.pdi to *.iso and then burned the *.iso with RecordNow Max it played great in my set top player.
After reading what some others have stated I will install the update to Instant Copy so the final disk will have a AUDIO_TS folder and be more compatible with older players.
Again thanks for the link rather then just saying you need to get this and install it. (PDITools).
Dragonfly2337
Ripping A DVD: Can I Just Copy The Files Myself?
By SetoTitan in forum DVD RippingReplies: 8Last Post: 22nd Mar 2012, 12:03 -
cannot burn or copy captured mpeg2 files
By DirtBikeMike in forum Capturing and VCRReplies: 12Last Post: 3rd May 2011, 07:49 -
cannot copy files to computer or copy dvd
By moshik16 in forum Newbie / General discussionsReplies: 0Last Post: 14th Feb 2010, 16:09 -
I cannot copy my DVD files
By josealberto1975 in forum Software PlayingReplies: 10Last Post: 21st Nov 2009, 12:58 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
