I currently have the following setup for my ide devices and would like to know if a "PCI Ide Controller" had any problems like being slower then the ide slots on the mobo.
hda > os's and storage partitions
hdb > video capture partition and more storage partition
hdc > cdrw
hdd > DVD-Rom
I would to move hdb onto it's own ide line so it has a better change of keeping with my 768x480 stream copy's from my tv card. and I may include another drive for capturing.
So is there any drawback to putting a drive for captures on a "pci ide controller" and what would be a rough price for one of the cards?
Results 1 to 10 of 10
I have an extra PCI IDE controller myself!!! I don't even notice that there is one installed...! Capturing from DV or whatever source goes flawless!!!
I would recommend a Promise Ultra 133 PCI controller wich costs only 64euro (this is about 65US$)
greets
'HAG -
No problem for me either. I use a controller +1 year old, under Win98. A little problem is that asking device properties on IDE device is slow. Launching Nero freezes, say, 10 seconds. But apart from this, I managed to capture 1 hour in PAL D1 with my Miro DC30+ with no frameloss.
I saw a controller that does IDE/Firewire/USB2 on http://www.pearl.fr -
Just be aware that (some) PCI IDE Controller cards can cause problems if you attach to it ATAPI drives (DVD-ROM; DVD burner, CD...). At least that is what I believe is true based on posts that I was reading. I do not own such controller.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
@Fedd. What sort of IRQ resources does the IDE controller card use under Win 98? Can it be used at full speed sharing with say the graphics card or Soundblaster card m/b resources?
I have a SIIG PCI controller which has only my Pioneer 105 DVD burner on it. Works well for me.
I have a Promise Ultra133 card. Supports both hard drives and ATAPI devices--no problems. Bought it for $36 at Newegg.com including shipping.
Darkshadow -
I have Maxtor's Ultra 133 controller, with a 80gb 7200 Ultra 133 drive that I use exclusively for capturing. As others have posted, optical drives are an issue because they run slower - the controller is designed for faster drives. You may or may not experience issues.
I'm running Win 2k and I DO have a 50x cd-rom running on it. I get event logs daily, but the drive's performance doesn't seem to be affected. -
Hey . . .
Check my machine specs - the controller I use runs a raid 0 stripe array, and is used for both capturing and editing. I can capture (using Virtual VCR 2.6.9.6252) at 740 x 576 with maybe one or two dropped frames over a 3hr capture - gotta be happy with that!
Short answer - YES, they are worth it (BTW, that card cost me $50AUD about 4 months ago)
Cheers,
B.===============================
"Don't ask for my specs - click the b*&^dy button . . ."
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Seeking avisynth function for "blend-a-field" idea
By vhelp in forum EditingReplies: 2Last Post: 21st Sep 2008, 20:52 -
pci ide controller problem
By makemepure in forum ComputerReplies: 4Last Post: 29th Apr 2008, 21:20
