I have a mpeg2 file of 680 MB and converted it with tmpenc (mpegtools)
to a mpeg1 file via multiplexing
However after multiplexing the filesize becomes 225MB bigger which do not fit on one cdr.
Why does this happen, and can I prevent this?
trenchy
What settings did you use in TmpgEnc? And to what file did you convert to(I think only possibility ist MPG1 isn't it)?
It's not very clear what you have done. Multiplexing a file (with audio) does not change the stream type from MPEG-2 to MPEG-1. From what you say, the extra 225Mb are probably the result of multiplexing a video stream (680Mb) with an audio stream at a high bitrate (225Mb).
If this is the case, a way to avoid re-encoding the video could be to re-encode the audio for a lower bitrate (e.g. 64kbps joint stereo). This should reduce the size of the audio file to the extent the multiplexed file may well fit on a 800MB CD-R
Again, the above comments are guesswork.The more I learn, the more I come to realize how little it is I know. -
What I hav done is the simple vcdheadertrick.
What I only just did is in mpegtools (tmpenc) clicked on multiplex
I loaded the svcd file. with type[mpeg-2 vbr]
Hereafter i selected type: mpeg-1 vcd and hit run
This resulted in a vcd file which was 200MB bigger?????
I used this manual
http://www.vcdeasy.org/modules.php?name=_Guides&id=VcdTrick
trenchy
my xvid videos are too big in filesize
By C-Royd in forum Video ConversionReplies: 1Last Post: 6th Aug 2011, 16:31 -
Big blocks on XVid to MPEG conversion
By hewsongs in forum Video ConversionReplies: 7Last Post: 30th Mar 2008, 15:50 -
big conversion problems
By insyder in forum Video ConversionReplies: 0Last Post: 7th Jan 2008, 10:02 -
Big collection VHS to DVD conversion
By darkbluesky in forum Newbie / General discussionsReplies: 14Last Post: 6th Sep 2007, 20:49 -
conversion file to big
By jimk16 in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2007, 04:05
