    May 2001
    James Whitlow
    I captured a 30 minute show last night in 352x240 AVI. It created a 9GB file. I loaded it into VirtualDub and edited out the commercials. The resulting file will start up in Windows Media Player, but if I skip about a third the way into the file, WMP gives me an error telling me the file is invalid. In addition, when I encode the file into the final VCD, I get audio dropout at about a third the way through. Interestingly, the video is still there. If I play the original 9GB file in WMP, it plays just fine all the way through.
  2. My guess would be that Vdub has problems editting a 9 gig file. You aren't gonna leave it at 9 gig are ya? (It'll be
    years before someone comes up with CDs that can hold files
    that big )
    You could encode it and edit the commercials out afterwards.
    May 2001
    James Whitlow
    No, I am going to delete the 9GB AVI. What I want to do is capture to AVI in VCD resolution, edit in VirtualDub, compress to VCD with TMPGEnc.
    I could compress and then edit, but that puts me back in the same situation I was in when capturing to high bit-rate MPEG, editing & then compressing, which is that none of the MPEG editors that I have tried are frame accurate (or they are either overly complex or very slow). The most accurate that I have found is TMPGEnc. Most of the time, it is close enough not to matter. However, sometimes I will cut at a commercial fade and get 1-3 seconds of the commercial.
    The worst that I have found is VCDCutter.
  4. I found editing mpegs to be a nightmare.
    You could use Vdub to compress your 9 gig avi to divx, edit that (DivX edits very well), and then use TMPGenc to convert it to mpeg-1.
    Off course the extra step (DivX) will cause you to loose some quality, but if you play the endresult (VCD) on a TV it might not matter since VCDs often look better on TV than PC.
    In any case if you experiment with compressing your avi it would be a good idea to cut out a small segment (1 min or so) out of the original so you don't have to wait half a day just to find out your settings didnt give you the result you desired
    May 2001
    James Whitlow
    What would you suggest as the best compression codec for AVI files that gives good compression without too much loss in quality?
