Hallo there.
I have a problem and hope u can help me.
I converted DVD ManInBlack PAL Full screen to a Standard VCD Mpeg1 via dvd2avi and TMPEG.
After cutting off leadin and leadout the Stream had a size of 889000 KB
I want it on one CD ! Burning 800-830 MB is no problem.
SO I converted again setting audio bit rate to 128kbps ( before 224kbps)
Again : File size about 889000 KB
I did TMPG Mpeg1 Video only : .m1v size 750 MB
With panasonic mpeg1 encoder i did a .mp2 128kbps with 75 MB
an 224Kbps with 145 MB.
I tried multiplexing with bbmpeg and with TMPG ( both files on each )
I always get the same file size +- 2 MB
750 MB + 75 MB = 900MB ? ? ?
That really dirves me mad !
1) What do I wrong ?
2) Is it possible to get a smaller file without changing the standard VCD settings ?
3) Do i have to alternate bbmpeg settings ?
4) Do I need other progamms ?
Pleeeeaaase help .
1 - You're doing nothing wrong
2 - With TMPGEnc that's impossible to my knowledge. Even at a lower bitrate than VCD standard, TMPEnc will add "junk bits" in order to attain a standard VCD standard rate as a "MPEG-1 VideoCD" stream (at least 1374 kbps). Vice-versa TMPGEnc won't take away bits (that's how XVCD works for HIGH stream bitrates and is VCD Compliant).
The only thing I can think of is to turn off Standard VCD Compliance and lower everything under 700 Megs (only standard VCD files can go as high as 800 Megs to fit on one disc).
Changing audio frame rate?
By architectofpain in forum AudioReplies: 22Last Post: 5th Apr 2013, 11:27 -
How to reduce Audio Bit Rate
By mad_mackem in forum Video ConversionReplies: 6Last Post: 28th Dec 2011, 10:30 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
audio bit rate showing in video
By soulman1015 in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 11:44 -
how do i know if Nero is changing my audio bit rate?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 19th Nov 2008, 16:49
