Hello. Does anyone else have a problem with firmware 1.4 and the player not being able to read a RW disc of any type (CD/DVD)? I upgraded my player a month ago and have not been able to read or write to a RW disc at all. I tried Nero (several versions) and GearPro DVD 6.0 to no avail. Any help would be great. Thank you.
Jason
I use ULEAD DVDWS & it only burns to DVD-RW successfully. Then I can use Nero to "copy" the DVD to a DVD-R. If I try to burn straight to DVD-R it always skips at some point in my standalone. I'm using the 1.4 firmware also.
I had a similar problem with the 1.40 firmware. But in my case i couldn't erase an RW with any program, and if i tried it would ruin the RW disc with errors.
I did some searching and found out that the 1.40 firmware is rather "buggy". However some people will argue that.
Anyways, to fix this, i used the hacked downgrade flash. The flash prog searches for the key to your drive and then processes and flashes your firmware to whichever one you want. Im currently running 1.33 2X for all.
I haven't had no problems whatsoever and i can once again erase RW's.
P.S. Im not sure about posting links for this sort of stuff, so if u wanna know where to find this, then PM me.
Pioneer DV-220V-K firmware
By totonionio in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Apr 2013, 09:45 -
Pioneer DV-S838A firmware
By zhudinglong in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Jul 2011, 02:12 -
Pioneer DVD recorder firmware
By jh76 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Apr 2009, 03:03 -
Pioneer DVR-216 and Firmware
By dqtus in forum DVD & Blu-ray WritersReplies: 5Last Post: 27th Mar 2009, 03:26 -
Help, firmware update problem of Pioneer DVR 630HS
By stepw in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Oct 2008, 12:05
