I'm posting for a friend.
I just recently got a 1GHZ powerbook with a superdrive and I am wanting to backup some DVD movies of mine. I know this has probably been covered a million times already but I am new to all these terms and I am rather confused. Can someone tell me what programs work well to A: rip the original DVD to my HD and then B: what to use to burn it so it plays in most DVD players. Thanks.
Are there any easy to follow step by step guides? Can you link me?
Thanks!
http://homepage.mac.com/kaicherry/index2.html
DiscomVOBulator and DiscomVOBulatorPlus allows you to make a DVD backup of a DVD Title track. It does *not* clone DVDs, or Re-encode them. If your DVD title is too big to fit on a single DVD-r, it will automaticall be split to fit onto 2 Disks.
You can then add chapter marks using the built-in Visual Chapter editor. Just move the playhead to where you want a new chapter and click the Mark button! The whole process from start to finish takes 1.5-2hours, depending on drive and cpu speeds. Subtitles are not currently supported.
NOTE: Most all dvd's will require 2 dvd-r if you want an exact copy. Heck, even if you want just the movie file itself in the EXACT quality as the DVD.
To get it to one disk, you need encoding software. There are TONS!!!!! personally, the program Forty-Two offered by the same people works ok for this.
I suggest strongly supporting them with a donation if you decide to use these programs. The 1st is a demo which you can later buy (HIGHLY RECOMMENDED) the second is free, but you should make a donation given how much effort and time they put into this amazing program.
Before these guys, it was a HEAD ACHE to do any of what we so easily do today with DVD to anything conversion.
Enjoy
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 09:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
