Is it possibile or are you going to dash my hopes and slap me in the face, whats the best tool, i have tmpeg??
so the guy punched me, and later i stole his parrot as way of revenge
you could make it uncompressed .avi, thats the highest quality of anything availible... but that takes up massives amounts of space tho...
Time's not wasted when you're wasted all the time. -
How would i even think about trying it?
When you say lots of space? how much like more then say a full DVD rip?
ill try anything once i supposeso the guy punched me, and later i stole his parrot as way of revenge -
No one is answering because your question doesn't make sense. What do you want to do with your video: watch on PC, play on DVD player, streaming media, etc. No matter what you do you CAN NOT improve on the source quaility. So there's nothing better than what it already is.
GIGO, any conversion will only reduce quaility (by definition, you may or may not be ablet to see a difference). -
To make it uncompressed the easiest way is to use virtualdub. Open your avi then select Video-->Compression then select "(Uncompressed RGB)". Then under file select save avi. Your resulting filesize will depend on two things: resolution and #of frames. It will probably give you a 24bit RGB uncompressed file which means it uses 24bits/pixel. So you can calculate your filesize (in bits) by doing this: 24*(horizintal pixels)*(vertical lines)*(#of frames). Your filesize will most likely be considerably greater than a dvd rip. I don't know why you would want to do this because you'll only get bigger filesize and the SAME quality as your avi. If you recompress it to anything else other than a lossless form (i.e. HuffYUV), which will only give you about half the filesize, you'll be guaranteed worse quality. Remember "Garbage in, garbage out".
Also, I believe it against forum rules to bump your topic up. Anyways, it was only ten minutes since you last reply, sometimes it takes days to get your questions answered. This is a forum not IM so please try to be a little more patient next time -
Well thanks guys
looks like im left with the poop version well i was gonna try but like you say
garbage in garbage out thanks all the sameso the guy punched me, and later i stole his parrot as way of revenge -
MPEG2 is pretty good, after all DVD uses it.
But as said, what is this for?
The answer for DVD is different than streaming video, etc.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
