  1. how does one frame serve to TMPGEnc? Every time i try to open the .vdr VDub makes with TMPGEnc, it just freezes. I looked at the guides section but couldn't find one for VDub frameserving to TMPGEnc....
    Time's not wasted when you're wasted all the time.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Now there's a guide that I'd like to see!
  3. 1) Did you install the file handler for Vdub to allow frameserving? (https://www.videohelp.com/virtualdubframeserve.htm)
    2) Can you open/play the VDR file with WMP?
    3) Have you tried applying the VFAPI codec to the VDR file (to generate a avi file).
    4) You leave VDub open right (frameserving only works if both programs are running)?
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
  5. I installed the file handler, WMP cannot play the .vdr file, i dunno what u mean in #3 and yes, i am not a complete n00b, i do leave vdub open
    nuttin
  6. a file is missing in the TMPG directory
    at the moment i donīt know waht file but try to put vdub in the same directory as tmpeg, install the handler for avi-client only in vdubthe problem should be resolved
    2man
  7. i installed the two programs in the same directory, still nothing
