Hi
I want to burn an audio book onto a DVDRW so it will read like a CD Audio track. Any Ideas?
First of all your DVD player has to support 48khz mp3's.If it does then download CDex and rip your book to mp3 48khz,burn as data ISO or UDF.
www.cdex.n3.net -
These are your choices (test each and find out which one works-use RW media during testing
1. Make MP3 files (44 or 48k), burn as simple data files onto CD media-ISO9660.
2. Same thing, but burn onto DVD media-ISO9660/UDF bridge.
3. Make a regular Audio CD--multiple discs.
4. Make LPCM, MP2 or AC3 files (48k), Author along with still pix as std. DVD-Video and burn onto DVD or CD media.
5. Make LPCM or LPCM/MLP files (44, 48, 88, 96k), Author with or without pix as std DVD-Audio and burn onto DVD or CD media.
Sounds like you want to do #2 but don't think you can. How long is the title(s)? Don't do #5 unless you've got a universal player. If length isn't rediculously long and/or you don't mind compression, do #1. If length is quite long (>10hrs) or you do mind compression, do #4. No matter what, you've always got #3 as a fallback.
Trying to clarify things...
p.s.: THERE IS NO SUCH THING AS CD AUDIO TRACKS ON DVD MEDIA. All DVD's are "Data" discs, using UDF or UDF bridge filesystem. Some may be just raw data files, some may be authored std DVD-Video material, some may be authored std. DVD-Audio material,some may be combinations of the above, but on a DVD, as opposed to a CD, it's all just data.
How to burn HD movie files (.m2ts, .mp4, .mkv) to standard DVD
By neworldman in forum DVD RippingReplies: 4Last Post: 17th May 2010, 12:01 -
Can I burn more audio (.mp3) files to my CD-R more than once?
By Nintendo Fan in forum ComputerReplies: 23Last Post: 25th Mar 2009, 21:10 -
Shot in HD - burn to standard DVD
By revlis in forum Video ConversionReplies: 1Last Post: 6th May 2008, 22:56 -
How to Burn standard DVD
By hmanhha in forum Newbie / General discussionsReplies: 5Last Post: 26th Feb 2008, 09:57 -
Burn standard DVD project to Blu Ray disc?
By whoisquilty in forum Authoring (DVD)Replies: 12Last Post: 24th Feb 2008, 15:21
