Hi,
I use the NeoDVDPlus4 authoring software in order to burn music video clips.
The soft works perfectly with PCM audio tracks but once I have a clip in AC3 or DD 2.0, the soft refuses it and I cannot integrated it in my DVD compilation. NeoDVDPlus4 informed me that its software could not work ac3/DD format, because of a too expensive licence.
The question is then the following :
1. Is there a way to convert AC3 in PCM format (in/with VOB file) ?
2. If not, do I need to change my software and which are the ones that could enable me to use AC3 ? I am considering buying a Ulead software.
Thank you
Emmanuel
You can use besweet to turn AC3 into a .wav file. You will need besweet and the gui for it. Look under tools to your left for both.
May the force be with you. -
Or Goldwave.
"Art is making something out of nothing and selling it." - Frank Zappa -
Or graphedit
dhluke
Difference Between DTS 5.1 & Dolby Digital AC3 5.1
By dorababu in forum AudioReplies: 8Last Post: 31st Mar 2013, 22:31 -
Dolby Digital PLus (ac3) track to FLAC error
By Edgarke16 in forum AudioReplies: 0Last Post: 27th Sep 2011, 00:38 -
Splitting AC3 Dolby Digital 2.0 (surround) into seperate WAVs?
By Asaki in forum AudioReplies: 2Last Post: 29th Apr 2011, 15:18 -
Convert PCM to AC3???
By ivano09 in forum Video ConversionReplies: 6Last Post: 17th Feb 2010, 13:08 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54
