  1. is there a tool out there that would tell me the ratio of the movie? cause the software i am using doesn't have a ablitlity to select "full screen keep aspect ratio" so i have to enter the correct number if i don't want the image to be streched to much.
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    well, work it out. you know your output file will either be 1.333:1 (normal TV) or 1.777:1 (wide TV)
    they are the only two aspect ratios you will ever need to know for dvd conversions.
  3. First, Gspot (look under tools or at doom9.org) can tell you all this.
    However, as far as display aspect ratios go. That's a bit more of a mess. There are 3 that you are likely to run into:
    1:1 (PC)
    4:3 (standard tv)
    16:9 (wide screen TV and film)
    However, widescreen TVs have an actually DAR of 1.77:1 and films come in either 1.85:1 (academy flat) or 2.35:1 (anamorphic scope).
    VHS, VCD, and SVCD have a DAR of 4:3 ONLY. That means to display film sources at the correct aspect ratio you have to letter box your video. But DVDs can be anamorphic. You flag a DVD as either 4:3 or 16:9.
    A 2.35:1 encoded anamorphic DVD actually has little black bars encoded as part of the video (sort of a pseudo-letterboxing). Otherwise even on a widescreen TV the picture would look distored (widescreen TV 1.77:1).
    So depending on your source, and what you are trying to encode too there can be a lot more variables in play
    Take a look below for more info:
    http://www.doom9.org/aspectratios.htm
    http://www.thedigitalbits.com/articles/anamorphic/aspectratios/widescreenorama.html
