I have tested Instantcopy on alot of movies and as far as the movie is 7 gb or smaller it produce a nice outpot quality after the encoding. However I just tried The Sum Of All Fears, about 8gb. I strip the audio and subtitles just keep the english 5.1 sound. I set all the extras to 42 % and main movie to 76% and ended up with 4,36gb pdi files.
I then run some quality tests. The extras looked prety bad, but I had not expect anything els, because only 42% of original. Then I tested the main movie on my 32' TV and it looked almost as good the original. But when I run the movie in Power DVD and zoom 9x it looked very very blocky. It was blocks almost all over the screen and thats not good. So I guess it's not recomanded to reduce main movie under 80%. Thats my conclusion anyway after this test.
What experienc do you peopel have of backing up big movies(around 8gb) with Instat?
Yeah, 80% is about right. Anything below sucks. I don't know about zooming in at 9X
Even the original will have some blocks at 9X.
I tend to not watch my movies zoomed.
I did Rocky Horror at 56% recently and it turned out okay. Of course, the source is pretty old, so it didn't look great to begin with.
-Robert -
in that case strip off some extras or reduce to 30% (basically there but no watchable) to get main movie over 80% and you'll have awesome quality. Zoom 9 times on the original has no blocks?
Well I tried the same movie with dvd2dvdr (using CCE) and it didn't come out much better. I guess that the original movie quality is pretty crapy so I should not blame Instant for this I guess.
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad quality downscaling...
By Emillister in forum Video ConversionReplies: 33Last Post: 29th Aug 2009, 12:48 -
Bad quality with VobSubs
By Xavier in forum SubtitleReplies: 1Last Post: 19th Apr 2008, 02:31 -
Bad video quality
By windofice in forum Newbie / General discussionsReplies: 8Last Post: 16th Jan 2008, 21:20
