on easy cd creator 5 what is the system clock reference?
and how can i change it.
I'm not quite sure what system clock reference is but it has to do with how it is muxed. Ez cd creator seems to be the only program which has such a strict check on it.
To fix it demux in TMPGenc and then remux with mpeg1 vcd set to output. The resulting mpg should have a compliant system clock reference. -
Sorry...
demux=demultiplex
In TMPGenc go to file/mpeg tools/Simple De-Multiplex. Load your mpg and hit run. Wait til its finished, even if it seems like it locked up. Now click on Simple Multiplex and load your two files that you just created, (m1v and an mp2.)On type select mpeg-1 video-cd. Hit run and when its finished load this file in Ez cd Creator to burn, the system clock reference should be fixed now. -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Did you post this somewhere else ? as I answerd the same question a min ago ?
Easy Cd creator is telling you that the mpeg you have made is not a compliant VCD. If you chose to ignore this, it may not play on some players.
When you use TMPGEnc load a template (PAL or NTSC) dont change anything.
Unusual behavior of PC clock
By Seeker47 in forum ComputerReplies: 7Last Post: 22nd Aug 2009, 12:34 -
phillips 3575h clock problem
By resohed in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Oct 2008, 17:44 -
sync computer clock to broadcast?
By 4evrplan in forum ComputerReplies: 5Last Post: 9th Jul 2008, 15:36 -
Fall for Recorder Clock
By UnknownVT in forum DVD & Blu-ray RecordersReplies: 8Last Post: 12th Nov 2007, 09:06 -
Trutech 1620 clock
By jaybird206 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Jun 2007, 14:20
