Hi.
I'm trying to convert some avi's to DVD using MyDVD. The Clip lengths are 1 hour 10 and 1 hour 29, so I figure I'll have to put them on 2 DVD's. But neither of the two wil fit onto a DVD-R. The burn menu blanks out I assume due to the length of the media. I thought DVD's where supposed to hold 2 hours each? They are DivX4 avi's. Any ideas how I can record these to DVD?
Andy
its because sonic my dvd changes the audio to pcm and that eats up alot of space.
Try using CCE. Follow the guides at www.doom9.org. They suggest converting audio to AC3. I had a 2.5GB video file and the AC3 file was only 300MB
This is so much fun! -
you could also try encoding the files with TMPGEnc and buring them to DVD with the latest version of Nero. In TMPGEnc, you can choose the setting you want for your audio and video.
Time's not wasted when you're wasted all the time.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
