Hi!
Can anybody tell me how to covert a DVCD to 2 normal VCD discs? Thanks.
I assume you mean DVD to VCD or maybe DV to VCD, well either way you will find detailed guides to convert pretty much anything to everything here.
https://www.videohelp.com/convert
Good luck. -
No, I really mean a format that's called DVCD... and I couldn't find it in the conversion guides...
Please help me... -
I saw this link:
http://www.afterdawn.com/glossary/terms/dvcd.cfm
It says that Double Video CD (DVCD) is nothing more than an overburned VCD to include 90-99 minutes. So you need to convert it only if the movie is too long: after you extract the movie from the .DAT file using, for example, VCDGear, you can split it with TMPGEnc and then write the fragments again to VCDs.
Cosmin
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
